'00 F250 PSD Speedometer?
Lurch830
messin' with sasquatch
Wilton & Albemarle, NC
Friend of mine just bought a '00 F250 7.3l auto and he's noticed that the speedo is constantly reading 7MPH faster than he's driving. I'm thinking that its computer related, since I think any gear changing or different tires would be a percentage off instead of constant number. It supposedly was a Duke foreman's company truck. Any ideas/suggestions?
He mentioned this to me yesterday while he was picking up the wheel, but we both had to rush off so I didn't get a chance to discuss it with him.
You are correct, if it was a gearing/tire difference it would be off a percentage, not a constant 7mph fast. It is possible that work has been done on the cluster or something and the needle was bumped or moved. Is it at 7mph when it should be at zero? Does it go all the way to the stop when off? You can carefully pry the needle off (a fork works really well to pull it straight off). And then place it back on in the correct position. I have found the best method is to pull the clear face off the gauge cluster, remove the needle, place it back on, but not push it down all the way, take a short drive and compare either using an OBDII scanner or GPS, and then make any more adjustments if needed. Compare the speeds at 25,35,45,55 rather than at just one speed to be sure you get it right. When you have it right push it back down, but not too far, if you push it too far the needle may rub the face causing it to drag, reassemble the cluster and you are good to go.
I actually had to do this to my father's Nissan a couple years back, I have no idea how, but his speedometer needle broke off, I tried to repair it, but the plastic was so brittle it crumbled in my hands, I fixed it using a little chunk of rubber and the end of a zip tie glued to it and painted white to make a needle, he says it's still working great and is spot on, redneck repair award of the year if I may say so my self.
I seem to recall your friend also saying the truck was having issues with O/D. It is possible that the VSS is going out, a malfunctioning VSS would mess with O/D and ABS as well, but normally when it goes, the speedometer doesn't work at all, or intermittently, not a constant value off.
We're going to look into it this week/weekend when we get a chance, so I'll know more then.
According to him, its 7MPH off at 55, 65 & 70 and reads 0 when its stopped & off.
The O/D issue is with the button itself we think. He's done some online reading and it seems that the O/D wiring harness for the button is known for breaking wires, so I'll look at that to see if I can solder them back together.
He bought an edge programmer that says it can adjust the tach & speedo, so I may suggest using that to get it corrected rather than pull the cluster face. I've had to adjust plenty of gauges that way!
On an unrelated note, he came back to work talking about how much he liked your truck. Kept saying how sharp it looked!
I have heard the same about the O/D button wiring breaking, luckily I have a 6spd so no issues there.
As far as the Edge, if it is off a constant number, correcting it with the edge won't get it right either, as it will change it by a percentage, but he may be able to get it right at say 60mph, so that it would only be off slightly at speeds close to that.
Another thought, to be sure if it is a gauge or a calibration issue, have him drive down the interstate, zero the trip odometer when he passes a mile marker, drive 10 more miles. If it reads 10mi at the 10th mile marker the calibration is correct and the gauge is off. Make sure he does this to the mile markers, not the exit signs. Of course if he has a GPS he can do that to get a distance comparison.
Oh and thanks for the compliment haha!
