Tradarcher
- Mar 20, 2005
- Creedmoor, NC
My 01 Taurus just started idlilng about 3000 rpm. When you drive it you literally have to stay on the brakes. I've cleaned the IAC motor and I don't believe that is the problem. There is no change if I unplug the IAC so I am thinking I have a leak. I am also wondering if it is the TPS. Anybody ever had a TPS go bad? When one does go bad what are the symptoms? I figured the throttle would drop out instead of rev high when one went bad. What else should I check?
