redneckjeep87
Landscaper Extroidanaire
- Oct 10, 2007
- Woodleaf, NC
Before anyone says it, yes i have searched far and wide on this topic.
01 xj 184k on clock
have replaced coil pack, tps, and fuel pump.
I replaced the fuel pump when we got it with a bosch due to pump being bad. Then replaced the coil pack due to bad misfire problems. Everything was hunky dory for quite a while after that. Recently have been fighting a rough idle/ misfire and cannot get rid of it. I replaced the tps due to some reading online stating that they can cause some crazy problems, but no difference. When running the interstate for 7-10miles it starts misfiring BAD almost to the point you cant continue to drive it. Major loss of power almost like it is overheating but gauge reads normal right there at 210. The electric fan works as i testedit sitting in the driveway, left it running for awhile and fan came on. When sitting idling for an extended time it does pop the cel for misfire and almost acts like its loading up sort of like an over carbed engine will sitti g at idle. Any ideas? Could really use some help with this thing. Im fixin to do a compression test today to try and rule out a seeping head gasket.
01 xj 184k on clock
