02 tj springs on a taco
1drboy1
NC
any one know the size of the front coil springs for a 07 taco stock i got a buddy looking to do a small lift on his and we were hopin to save him some money by using the stock springs off my 02 tj but im not sure if they will fit/ add any lift. hopefully it can be done with out any major work hes not to keen on tearin it apart yet thanks
You can buy a small rough country lift for about 250 IIRC. If you're talking about a Tacoma which I think you are you won't be able to use TJ springs, they're probably half the spring rate that you need. A bolt on spacer is what you need.
