05+ superduty ball joint strength.
Jeff B
Thanos was right
Lincolnton N.C.
what is a relatively safe tire size for spicer ball joints before going to eliminators?
going in an xj with a 4.7 stroker.
Stock oem balljoints would be fine. I would install new one vs trusting unknown mileage used ones. From that I have seen….it’s usually a broken u joint or shaft that takes out the balljoints.
Factory will hold no problem, until you roll it over or break a ujoint.
It's pricey, but I'd love to throw Reid Super Kingpins on mine. They're just...so...beautiful 😭😍
Keeps the factory hub bearings and brakes, but now you've got sweet, sweet kingpin goodness and can easily use a separate steering arm/highsteer and use regular ol' 1 ton Chevy tie rod ends and a straight tie rod...or tie the steering arms together for double shear. Whatever your little heart could possibly desire. Maybe more like whatever you could afford after their purchase 😅
Fancy! to much for my budget though. Very nice!
Thanks gentlemen, Ill order up a set of spicers
