NCcummins
NADEAU
- Oct 31, 2007
- Asheville, NC
I have a 2007 Chevrolet (new body style) 1500 with the 5.3 in it. It dropped a lifter due to the DOD/AFM right at 130,000 miles. Has anyone else with the newer LS motors done a cam swap and/or a DOD/AFM delete? My truck is currently in the process of having this done. It's not an easy task trying to find every part needed but so far this is what I have:
The following from Comp Cams:
XR275HR-12 222/224 cam:
http://www.compperformancegroupstor...Code=CC&Product_Code=54-426-11&Category_Code=
High Performace LS1 Valve Springs:
http://www.compperformancegroupstor..._Code=CC&Product_Code=26918-16&Category_Code=
5/16 7.400 Magnum Push Rods:
http://www.compperformancegroupstor...e_Code=CC&Product_Code=7638-16&Category_Code=
Hydraulic Roller Lifters:
http://www.compperformancegroupstor...re_Code=CC&Product_Code=850-16&Category_Code=
3-bolt Timing Chain Set:
http://www.compperformancegroupstor...re_Code=CC&Product_Code=3172KT&Category_Code=
We have the plate to block off the AFM. It pretty much just replaces the AFM plate and blocks the plug holes. We are also replacing the oil pump while we can since it has 130,000 on it.
Hopefully, this is all I need to finish this. After it is put back together, it will be getting dyno tuned in order to correct the computer and electronically delete the DOD/AFM.
If anyone else has done this, please let me know what else I need or what route you took.
Thanks!
Thanks!
