YotaOnRocks
- Jul 17, 2007
- Madison
My BIL decided to change his trucks fuel filters a couple weekends ago. Long story short he broke the top filter housing cap and had to get a guy that works for us come help remove it. While waiting for help he decided to go ahead and change the lower filter.
Once the broken cap was removed they vacuumed the housing out and installed a new cap and filter. After the system failed to self bleed they hooked a bleeder fitting up on the fuel cooler back port. They got the truck to crank and let it run for 20-30 minutes at idle. They then shut it down and replaced banjo bleeder with factory banjo bolt and it hasn't cranked since.
I showed up Monday morning and removed the top filter housing and cleaned it( there was plastic debris and metallic specs in the bottom of housing) and also blew out all the fuel lines that I could disconnect at both ends. I tried to bleed the system again. Flow to filter housing seemed weak and the lift pump was a little noisy so after a couple hours of unsuccessful bleeding I replaced the lift pump and put 2 new filters in.
Still no start. I then removed the stand pipe in the upper filter housing and cycled the pump on 20 times and tried to crank it. Nothing. But when I opened the filter housing back up to reinstall the stand pipe the upper housing was bone dry. I thought I had finally gotten the suspected air pocket in the high pressure side. But after refilling the housing with fuel and reinstalling the cap I have nothing.
I've worked on this thing for 20+ hours now and am way past frustrated. Hoping someone has some insight. I got the advice to remove the stand pipe from Lucas @mysterync who was kind enough to take time from his day to help.
Thanks for any advice or suggestions in advance.
