1.25" body lift
offroadn
Raleigh
When installing a 1.25" body lift on a TJ that has 2.5" RC suspension lift, does it need to have a 1" motor mount lift? Pros/Cons of not doing one.
Need is a strong word.....it can be done without it. Recommended........I would. Better driveline angle doesn't hurt.
Like Zubz said, you can do it without it. Most body lift kits have spacers to adjust the fan shroud if you don't do a mml. However, there's no good reason not too. They're cheap, easy to install, and improve your driveline angle. I'd highly recommend going ahead and doing a mml while you're doing the body lift
