userbmx1315
builds more then wheels
- Feb 8, 2008
- Bessemer City, NC
is there a way to bend 1.25 solid bar stock?
i'm building my new trac bar for my wj knuckle swap.
Honestly I've never tried to bend it that way. I will do the math in a few minutes and figure it out. Typically, solid stock steel is lower strength/hardness than mechanical tubing, which helps. Also, the leverage required to bend larger tube (say 2") likely offsets the lack of material in the middle. I'll get to the math in a little while.I know your gonna prove me wrong, but Matt, I would think it would take a hell of a bender to bend 1.25 solid wouldn't it?
My vote goes to the torch and ass as rich said.
Regardless of what the numbers say, I'd be willing to try it. I've got an 1-1/4 die I've never used.matt. if your bender will bend it then your the guy i'm going to, to build my trac bar/bracket. i'll drill n tap one end that way you could bend it and add the axle end.
if that sounds good to you.
just pm me a price and some info on plans on how to doit. i'm not in a rush still building the other d30 with wj knuckle swap
I didn't think you were. You seemed honestly intrigued.I don't want you to think i'm being a smartass, i was intrigued that it was even thought of. In my mind it doesn't sound feasible. I'm truly interested in seeing if it works on paper.
