Matic
- Jan 17, 2011
- greenville, sc
So I have done some searching on various forums about this swap and there is alot I don't understand.
I have a running 1.6 8 valve tracker engine that I would like to swap in my 88.5 Samurai.
if I swap the entire engine with the fuel injection I will have to modify the wiring harness in the sammi correct?
If I use the 1.3 intake and carb on the 1.6 will I have to modify the Sammy harness at all or will it just fire right up and run.
I have read that the petroworks 1.6 conversion kit is about the best on the market because you don't need a body lift to get clearance for the carb. Can anyone verify this?
and do I need a suspension lift before I swap engines?
Basically I want to be able to pull the 1.6 from the tracker, put my 1.3 intake and carb on it. Attach the petroworks adapter and drop in back in the Sammy. Is it that easy?
Also...what about using the 1.6 and the tracker tranny and t-case in the Sammy. That way I can get the adapter to bolt the Sammy t-case behind the tracker t-case for lower gears. Will it fit?
Thx for the help in advance.
