Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Just finished swappin a 1.6 into my buddies sammi cause he blew his old motor but wecan't get it to run, he just posted over on the zuwharrie board but i figured i'd copy it over here in case any of you guys have any ideas.
Thanks
We just finished swappin in an 89 1.6 8v into my 87 Sami. We kept the 1.3 carb/intake. We used a holley low pressure electric fuel pump (1.5-4.0 psi).
For some reason the motor will not run. It will turn over, the starter is good, the timing is all lined up, we have all new plugs, rotor, cap and wires.
We've tested and got good spark. The compression was tested before I picked it up and it was good. We have fuel getting into the engine, the choke is working correctly and I know i have good gas.
We have also tried to start it with starting fluid with the fuel pump turned off( i wired a switch on fuel pump) and it still will not start.
We've done everything we can think, does anybody have any suggestions? Also if anybody is close to NC state and wants to swing by to take a look that would be awesome.
Thanks
Thanks
