SwamperXJ
Active Member
- Sep 27, 2006
- Greensboro NC
Ok guys, let me start this off with the reason for the build.... I bought a 91 Cherokee last year for a build with stock axles, and to run 38's (Insane but possible) So I started the build off....... I used the factory open dana 30 HP/dana 35 C-Clip open and regeared with 4:56 gears. Decided to do a whole Custom DOM Long Arm Kit with Johnny Joints and a Custom 3 Piece Crossmember. The Lift was a brew of 9" Rustys Coils with 3" Poly spacers, the rear was 8" leafs with 3" blocks, which ended up nice and level F/R. Its Roughly a 12" Lift.
Ran This setup for about 6 months/went to URE/Local Trails without any problems, then got offered a set of mild built stock axles to swap in, so I took the deal. Front dana 30 HP with 4:56 Gears/Lockright Locker/Chromo inner & Outer Shafts/Spicer Joints. Rear was a Dana 35 Non C-Clip with 4:56 Gears/Lockright Locker/Stock Shafts. This setup worked great UNTIL I started shearing ring gears completely off, after the 2nd ring gear died, I replaced it one last time. Once this was done, it was great for a few months on the trails around here, UNTIL I went to URE again. Thats when all hell broke loose. It started when my rear locker exploded, following that I started to beat on it to get up the ledge, thats when both front U-joints Exploded and sheared the Ears off the inner Chromo shaft, then Sheared the Shaft and Splines off the Short Side Chromo in the carrier, and twisted the Long side splines. At this point I just needed to get out of the trail, and when trying to do this, both passenger Side ball-joints sheared off and the wheel folded under the Jeep. Needless to say, we dragged the jeep out from Daniel on 3 wheels.....
This is the reason for the 1Tons. I got tired of dumping money and getting nowhere. Start Date 1/13/12.
Feel free to chime in during the build.
Parts so far for the build:
-Dana 60 Kingpin front
-14 Bolt FF rear
-Eaton Detroit No Spin Front Locker
-Dana 300
-42x15x15 TSL's
Still waiting on more parts to arrive.
I'm going to post pics and details as we go along and try and keep everyone updated.
Heres pics of the jeep before the build and during the teardown.
Starting the teardown...
-14 Bolt FF rear
-Dana 300
-42x15x15 TSL's
. I dont know if Im going to drop it yet, still cant make up my mind.
