Ok, I pulled the cap. Then its the huge outer 6 prong nut that incloses the smaller gear for the locking hub. Inside of that is the snap ring that holds the axle shaft in. There is not a larger snap ring around the nut, like on my 60. So the only way it looks like this thing is coming out is to have that socket. Then behind all this (hub body) should be the locking nuts for the wheel bearing, then wheel bearing, then the rotor should come free. However I can't even get into this thing. I've been to 2 autozones, all they have is the 4 prong which is too small to even catch any of the 6. Napa has a 6 prong, but it's also to small. Haven't tried Pep Boys yet but with my luck they probably don't have it either. So yea, basically I'm just looking for a socket big enough to fit this sucker. The diameter of the 4 prong socket I have is 2 1/4", the 6 prong is 2 1/2", and the nut itself is right at 2 3/4".
