- Jun 19, 2007
- high point
After a tank of bad fuel that locked up the injection pump on the tool truck(5.9 24v) it also took out my trusty 12v. I filled both up at the same time. It locked the pump up and the pump spun on the shaft shearing off the key way...
We had to remove the front cover and heat the gear only after I spilt the shaft with a puller so we had to cut the end off the end of the pump shaft. It was a b#@$^ but it runs with a new pump. Now i have to just put the rady back in. All this from a tank of bad fuel, it gummed up the pump and looked like dried pancake syrup.....
