1310 Driveshaft question
vanguard
Apex, NC
I have a 1310 driveshaft with a CV joint on one side. By just eyeballing the driveshaft it looks like a regular 1310 u-joint is used in the CV section of the driveshaft too. Can somebody confirm that I'm on target and that there isn't a special size for the CV u-joints compared to the pinion side of the driveshaft?
I've always understood they were the standard 1310 size.
^x2
I don't know about others but my 76 cj5 has the same setup and they're all 1310's. (spicer 0153x, napa 210-0153 but get the spicer for 2 reasons, 1 it's better, 2 the regular grease fittings wont fit, you need the ones that look like an inverted cone, to work with a needle adapter)
I've replaced 3 u-joints so far. I'm not the fastest but I can do it just fine.
From breakage? Sounds like you're due for an upgrade. :flipoff2:
One was a 1310 from breakage. The clip came out of place and the cap worked it's way out of the yoke. The second was actually a friend's and it was a toyota joint. In fairness, I was one of 4 guys that worked on it. The last was because I couldn't get the darn drive shaft removed and I was going to swap it from the CV down.
In the end we got it removed properly. Still, this upgrade idea sounds like a good one. :)
Ohhh, it sounded like they were all on your buggy... :p
an easy way to find out ujoint size is partsamerica dot com. If you know the donating vehicles anyways, look up the parts and cross reference to the known part.
an easy way to find out ujoint size is partsamerica dot com. If you know the donating vehicles anyways, look up the parts and cross reference to the known part. Napaonline works better though, most of theirs show the ujoint measurements.
