14 Bolt and 10 bolt ??
pikapp691
Raleigh
Whats the going rate for 14 bolt rear and 10 bolt front.
I am coming into a set and not sure if I will use them or not. The 10 bolt is pretty much complete with disk brakes and steering components. The 14 bolt has no brakes.
Unsure of what they came out of and would be sold As is. I am trying to gauge a price range for these because I know people like and use these. Thanks
Depends on what they are. If the 14 bolt is a Full float then it could be worth a little more. I have seen them sell for $75 and as high as $250 for a stock 14b. Figure around $100-$150 unless it has a locker or the exacxt gearing someone is waiting on. It is all about timing and someone needing/wanting the item at that time.
As for the 10 bolt this is a wide range of prices here. If someone is looking for a replacement then the gearing is importent. As far as using a 10 bolt as an upgrade I would only do that if it cam with the the 14 bolt and it was a set. Unless I ran a smaller truck then it might be an upgrade over stock.
Are these 8 lug? More info would be very helpful in determing a price.
The 14 bolt has no brakes.Thanks
A lot of times the 14 bolt hub a brake drum are the same pc, they were on the one we had and if you say it has no brakes are you saying it has no drum? Does it have a hub? Was it cut for Disk? IS the axle still in place?
Pic would help you know.........
Does the 10 bolt have lock outs or auto? Warn or cheep crap?
See that can make a difference in $ Warn lock outs sell for 80$ or so.....
Thanks for that link
The 14 bolt is FF. It is missing the drums. I believe the 10 bolt has Warn lockouts but not 100% sure. Working on resizing pics. Thanks
