14 Bolt Detroit ?
off_road2
Hickory
I installed a 14 bolt 10.5" FF detroit locker and it seems that the locker allows the wheels to have a excessive amount of play between forward and reverse. Looking a image of the detroit it appears that the teeth layout migt allow quite a bit of movement...is this normal?
This isn't my first locker install by any means, but can this be installed in a wrong fashion to allow excessive "tire backlash" or is this normal to the function of this locker?
I've got 5.38 gears and the pinion appears to be able to turn approx. 1/4 turn maximum before the locker begins turning the tires...
it actually reminds me a lot of how a lock right feels with that oversized elliptical-shaped hole for the center pin.
We take the big 1/3 round c-type clips out. When removed it allows it to lock quicker than waiting for the clips to rotate and fall back into their slot. Old circle track trick from Gant.
