jeepin1995
undecided......
- Oct 21, 2006
- Cary (raleigh) nc
bought a 14 bolt that has welded spiders..... i have a new set to install. i know on other axles, you can remove and install the carriers and parts in the identical place and be good on gear pattern..... but on the 14 bolt you gotta loosen the adjusting nuts to remove the carrier..... my question is this..... if i mark the holes on the adjusting nuts, and reinstall the little adjusting nut locks in the same holes they came out of, i should be good right??
