Baker
- Mar 25, 2010
- Suffolk, VA
that should be a full floater. the wonderful thing about a full floater is you can change the axle shaft without removing tire or brakes. the semi floater cover is shaped more like a football. ff is 10.5" gear and semi floater is 9.5" gear.![]()
I am not the authority but in the 1/2 ton stuff that they were put under I think you could go as high as 4.10. The 3/4 and 1T trucks had Eatons (HO52/72) and Dana (60) rear axles under then and 4.56 was much more common. My Blazer has 3.73s and the automatics of the day commonly came with 3.07s.
The eatons before 72. The 3/4 to and 1 ton after 72 both came with a 14 bolt there were a few exceptions but I have honestly never seen a dana 60 stock as a rear in a chevy.
Splitting hairs, Eatons *through* 72. I see the 67-72 boards from because of my Blazer and there are people with 60's under some 2wds, although I may be confusing the GMCs. To me they are all GM. Seems the 4x4s all have Eatons.
I kind of assumed the OP was moving up from 10-bolts so a 12-bolt is a direct swap with no wheel change. If I was going through the trouble I would do a 14-bolt as well, although the 12-bolt lives pretty comfortably behind some high Hp engines in the street rod scene. My brother puts down just over 600Hp to his '72 Chevelle 12-bolt and it hasn't grenaded yet.
