15x14 wheels! Advice?
94 Yota
york sc
Hi folks i got some 15x14s and i want that real baloon look like them trucks in hawaii lol no bigger than a 33" tall how wide should i go to get the baloon look? Any advice is apreciated thanks also any links to Pics so i could see
I use 8" wide wheels with 33's.. 10" wide wheels will make them look a little balooned. I wouldn't use anything wider than that. I'd say you'd have a hard time mounting a set of 33 12.50s on a 14" wide wheel:shaking:
but it can been done...
anyway, a guy around here ran 33x14.00 boggers on 14" wheels for a while.
If you have a wider wheel than the tire, you will probably blow a bead on the trail unless you run alot of air in them. Imagine how hard it will be to seat that on the trail.
I would not want to run a tire that was narrower than the rim...not the way they are designed at all...
a 12.5 on a 14 I'd seriously wonder if it could blow the bead at speed cornering.
Form needs to follow function as always IMHO....
If you got a big wide-assed inner tube, you could probably get it to fit.
But it will look really weird
You're probably going to need at least 1/2" more tire than wheel.
35X12.50 R15 on a 15X12 wheel
You are relatively new and local...we need more York folks.
The width is thee tread section width, by design the bead will be narrower than the tread section...so a 12.5 inch wide tire (33x12.5x15) will most likely be more like 11.5 wide at the bead area.
Now you want that to seal to a 14" wide rim. If you make it stick it wont stick well and if you off road at all the bead will break free leaving a flat (No issue for you, you said no off roading...have to wonder why you would want a 33" tall tire on a 4x4 and never off road but i digress) it can happen even on the road...a good rule of thumb to me is the tire should be 3-4" wider than the rim.
BTW if you evwr get that to seal it will wear very fast and ride like absolute ass.
I had trouble with the bead on 32x11 bfgs mounted on a 10" wheel. and they never seen trail riding.
i just like the "baloon" look. yes a buddy of mine has some pit bull rockers on 14 wides and his tires did wear fast. check out this link on youtube.. i like some of these baloon tire looks. http://www.youtube.com/watch?v=-JqZ-hZiAYs
thanks for everyones concern and forewarning. I have took in consideration of the tire coming un-beaded on road... i will reconsider... its just idk if i have enough lift to run a 35x15.50x15 on a 14 wide... o well.. ill trash this idea then.. lol thanks people..
For heavens sake, it's York. You know, the parking lot tug-of-war capitol of the world.
Well, at least you've got a good start for the big island stupidwide tire setup, a mid 90's toy. Next, how many chrome shocks per corner and stickers do you have? If you can find a shop that can mount them, 15x14's and 33" boggers are where it's at.
OK OK so No One else sees it but this is Obviously a Joke.I mean did you look at the Video He Mentioned???I live off Angier Ave in Durham so trust me I see this all the time,195/50/15's on 15X10 Rims or 295/50/15's on 15X14 rims running on a lowered Blazer.I also see them parked beside Pot Holes because it unseated the Bead under normal tire pressure,I wave as I go by.Besides he Doesn't even Spell Balloon right and I feel like I should be hearing "the Chicken Dance" in the Video He references.
well. lol.. i took my 36x12.50s to my buddys tire shop and we tryed and tryed to mount them to my 15x14s .. we failed :( so i was thinkin some 33x13.50x15 ltbs???
Who Even contemplates running 12.5 tires on a 14 wide rim??That's not Ballooned it's Dangerous,or maybe that's just me.
Idc how i spell on here. People understood wat i ment, all that matters. And yes i expiremented with my 12.50s. O well. Its no joke.
i had a set of 35 x15.50 sx on 15x12 wheels and they never had a problem with the bead. they were mainly street driven with trips to the beach. they did excellent on the sand due to the wide footprint. i am thinking thats why they do this in hawaii for the flotation to drive on the beaches. me, i think they look cool!:fuck-you:
you had 15 tires on a 12 rim he wants 12 tires on a 15 rim
I wasn't trying to be harsh,it just seemed a little like Shenanigan's
I dont want 12.50s on 14s . I ask for everyones opinion. Wat should i go with to get a balloon look? I just expiremented with my 12.50s.
