rcalexander105
JV Wheeler
- Nov 3, 2017
- High Point
Got a 1978 F-150 w/ the 4.9L 300ci straight six.
Tree dang near fell on it a few months back which forced me to move it from around back and into my driveway. This ultimately lit a fire under me to get it back on the road (or at least to start tinkering). I've been chasing an electrical issue ever since and I'm at a loss at this point.
Symptoms: If you put the key in the ignition and try to crank I get nothing. Even when you turn it clockwise one turn to ACC I literally get nothing...no power to anything. Gauges will normally register with key in this position and the fuel gauge will show fuel level and other electrical components would work (e.g., headlights, etc.) but I get NOTHING. @77GreenMachine came by a few months ago and we were able to get it running by jumping the starter relay from the positive battery terminal and finally got it to turn over and run. It didn't run great (sounded like it's had a miss) but it ran decent. Ever since then, it seems to have gotten progressively worse at idle and now I can't get it to crank (it'll turn over but won't fire off).
New parts thrown at it:
- Battery
- Alternator
- Starter relay
- Ignition switch
- Voltage regulator
- Cap and rotor (thinking it was running rough bc it needed a little tune up)
- Ignition coil
- Ignition control module (yea, that box on the driver side inner fender that's notorious for failing in these trucks)
Still getting nothing on the gauges or anything electrical (headlights won't even come on) unless truck is running.
I'm at a loss at this point. No idea where to look at this point. Any suggestions?
I LOATHE electrical issues!!!
- Battery
- Alternator
- Starter relay
- Ignition switch
- Voltage regulator
- Ignition coil
