ncsuwoj
- Jul 13, 2006
- Lynchburg, VA
Hey all,
I have a 1984 toyota 4x4 with a 22R in it. The truck cranks and idles great, has plenty of power but once it is warmed up and I start driving it has a tendancy to cut off. You push the clutch in to stop and let the RPM's drop back to idle and it cuts off...every time, whether I am on the brakes or not. It acts like it just doesn't catch itself. The idle sounds about where it should be, maybe even a touch high. It will crank right back up no problem. I have checked for vacuum leaks and found none. Any ideas on what it could be?
Thanks for your help!
