Altonymous
Lost Wheelin'
- Nov 4, 2013
- Clayton, NC
I picked up a 1985 4Runner SR5 (manual, 22RE). It had a refurbished 22RE motor swapped in, but the truck has been missing since I got it. I have been trying to track down the issue, and haven't had any luck yet. I've been scouring the forums looking for things to check.
Issues: Missing/Stutter ~2k-2.6k RPM
So far I've checked/verified/replaced/done the following:
- AFM - Checked, was bad and replaced.
- TPS - Checked and adjusted to in spec
- Wires, Plugs, Distributor Replaced (When I replaced the distributor I set to 5 degrees BTDC)
- Pulled the Throttle Body and Upper Intake Manifold and cleaned them
- Pulled the valve cover and adjusted the valves.
- Checked the timing, it bounces around a bit but seems to be staying with 12 degrees at idle
- Adjusted idle to ~750RPM
- Replaced the vacuum hoses (I still think there might be a leak, but I can't pinpoint it.)
- Checked the injectors, all reading 2.5 OHMs, also listened to them and they are all ticking like I'd expect when idling
- Compression Test shows 161-165 psi on all 4 cylinders (warm).
- Replaced the Knock Sensor. CEL is gone! (Still have the miss)
- Tested the ignitor and coil (minus the dry cell battery test) and it looks good.
- Fuel pressure while jumpered 38psi, while idling vacuum regulator hose pulled and plugged @40psi, and with regulator hose on @30psi, pressure remained above 21psi while off for over 5 minutes (Even increased a couple PSI.
- Replaced the injectors and redid the wiring. No more miss!
I think at this point all I have left is to look into is electrical issues. Is there anywhere else I should possibly look before I go down that route?
Any advice on which direction I should go and advice on order I should approach things?
