1988 ford f-250 diesel
LanceTJ
Member
Morganton
i looking at buying a 1988 f250 with the 7.3 idi diesel single cab 4wd. i was just wondering about them good or bad info would be great!
the TTBD50 will be fine on a tow rig. not the best ride in the world, but it will be fine.
great trucks will run 4 ever. 4 speeds are good 5 a little weak towing. 3 speeds autos are good. You can find a used turbo off a dodge and fab up the pipe. Turn the pump up and away you go. No powerstroke but a lot better.Several running around Davie and Yadkin from xxx diesel using the dodge turbo.
