CHECK LINK BELOW FOR CURRENT PRICES.
1991 - 1999 Jeep Cherokee 4.0L 242ci Stainless Steel Exhaust Manifold & Gasket Kit
Our replacement Jeep Manifold will fix that leaky exhaust sound coming from your cracked OEM exhaust manifold. Our manifolds are a great replacement for the original part and will fix the issue that you may encounter from a brittle original one.
This Jeep manifold and gasket kit have the following specifications:
Manifold
2 bolt flange
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Stainless Steel
Gasket Kit which includes the following items:
(1) Exhaust manifold gasket - Fits between exhaust manifold and cylinder head
(1) Exhaust pipe flange gasket - Fits between front exhaust pipe and exhaust manifold.
(2) Bolts, w/ (2) nuts & (4) washers - Hardware to attach front exhaust pipe to exhaust manifold.
Manifold
2 bolt flange
Direct replacement
Stainless Steel
