bannerp
- Dec 4, 2011
- Newland NC
Any help/input would be appreciated! I don't like throwing parts @ cars too solve problems but I'm almost at my witts end! BACK STORY-------1993 Hardbody SE V6 4x4 with a handshaker gets towed in with a no start complaint. Find timing belt broken and valves crashed customer doesn't feel like fixing the truck so i Bought it. Has ALL new valves, head gaskets, Timing belt, Distributor Cap and Rotor and spark plugs and wires. Has a slight missfire when idling and a slight surge when under load and under light throttle.
I have since changed too NGK V power plugs and NGK wires, Napa Premium Dizzy Cap and Rotor New Napa premium coil. New Fuel Filter. Cleaned injectors Using a SUBAR Cleaner and B12 Carb clean Direct thru fuel injectors. STILL MISFIRING!! Smoked entire intake manifold and found 2 small vacuum leaks repaired those. Replaced injectors 2-4-6-5 with reman Injectors and new Injector pigtails as they are known too fail. Cleaned MAF
Using a test light and backprobing old plug wires i narrowed the skip too cylinders 4-5 Checked compresssion on those 2 cylinders and 110 psi. And still a rough idle when on the gas truck runs like a champ!!!! When under load and slight throttle on small incline can feel the truck surge/Skip
Snap on Verus has no data and no codes in system. My next step is too change the 02 sensor i know they dont typically cause skips but if its reading wrong and not adjusting fuel trim accordingly maybe?!?
ANY INPUT WOULD BE GREAT!! ANYONE SEEN ISSUES LIKE THIS? THANKS IN ADVANCE!!
