fordtough
- Aug 8, 2010
- north western NC
I have just purchased my oldest daughter a 1994 Zj for her first car. It had been sitting for 2 years. Neighbor had the starter out and a new one sitting in the back seat when I bought it. I got the starter in and it would not crank with the key so I jumped across the wires at the starter and it fired right up. While trying to diagnose the starting problem I found 4 wires in the harness under the AC compressor that mice had chewed so I spliced them back together and checked the NSS and it is passing the tests. I also had found that I could use a jumper wire in the solenoid plug and it would fire that way. But after the repairs and checks I put the solenoid back in and it fired up with the key. That lasted for 2 days then I did a heater core replacement and it fired that night but the next morning would not crank with the key. I drove it around for a couple of hours and just for kicks put the solenoid back in and it cranked with the key. Did that for about 5 or 6 times through out the day and then again nothing with the key but it will fire with a jumper wire in the solenoid plug. Also a few other issues it does not shift smothly or regularly. It will shift but sometimes I have to rev it way up and let off the gas and as it comes down to 2k it will upshift and it will not down shift to 1st when stopped and taking back off. Fluid is full and doest not appear to be or smell burnt. And last for now the radio has no sound but turns on. Replaced with another factory radio and same thing turns on but no sound.
Thank you for your help.
By the way my daughter changed the oil in it with a little help but I am proud of her. I try to get her to do as much work as I can on it so she will learn.
