rustyolred
- Jun 9, 2008
- denton, nc
1997 Ford F-350 4x4 crew cab. 460 auto. SRW. What rear axle? 10.25 or 10.5 Sterling?
10.25, technically.
Also commonly known as a money-sink POS.
10.25, technically.
Well... Ford redesigned it three times in ten years. That alone should tell you plenty.
Back in the day, I spent probably $1500 putting one together only to have it junk two sets of pinion bearings and pull the threads on the pinion.
I spent $900 building a 14 bolt with a new detroit and discs. Drove it to Utah and back the next morning. It's still together today.
If you want to waste some time in the junkyard, go around to all the 10.25s and see if you can find one that still has a tight pinion.
People build them and get them to last... but when you can build a 14 bolt and get a stronger diff that's easier to service and cheaper to repair, why fawk around with the Ford axle? The only thing the 10.25 has going for it over the 14 is maybe the hub bearings are easier to service... and that's a good thing, too... because you'll have the hubs off twice a year replacing the seals, anyway.
Oh, and if you have a short rear driveshaft, the long snout on a 10.25 won't do you any favors.
Cut the webbing off the bottom and its not nearly the rock dragger that a 14b is. I think the difference is you're talking about putting interstate miles on one and others here are talking about cheaply holding up to large tires and trailer only.
On 97 up they fixed the pinion bearing problem.
hahaSee what I mean? Pieces of junk, all of them!
