Ton'dZon44s
- Feb 28, 2010
- Rocky mount
l have a 1997 GMC Sierra 1500 4x4 with the 5.7 Vortec. l had originally built this truck with a s.a.s. kit. l recently decided to set it back down and put it back onto an ifs frame. l swapped everything back. l bought new master cylinder, booster, pads, calipers, wheel cylinders, rubber brake lines, just to make sure all the braking system was good. l'vehad bad luck with brakes on this truck before. truck is back complete now, l've bled the brakes several times. l bench bled the master cylinder, done each wheel individually, even back fed them. Problem is, pedal is perfect when truck is off. Crank the truck and the pedal goes straight to the floor and will not pump up. l've done everything l know to do. ls there anything else to try or that needs replacing? Any advice would be great! Thanks.
