andrewlail76
- Jun 21, 2006
- Hickory, NC
Guys, I have the chance to swap my Mazda for a Trooper. Thoughts on each?
Well I was thinking of getting a trailer hitch and use my father's trailer, should I need to haul something.Do you need seats ? Because lossing a truck bed suckkks
This one is the 3.2. It is an automatic. Should I be wary of it? What should I be looking for?3.2l or is it late enough in 97 to get the 3.5l? there is a big difference in power.
i had a 97 with the 3.2 and factory front and rear Limited slip. what a goat that thing was.
the only concern is the transmission is about two sizes too small inthe automatic version. the 5spd should be fine.
not bad little 4x4s.
I was wrong...what I'm looking at is a 3.5This one is the 3.2. It is an automatic. Should I be wary of it? What should I be looking for?
It currently doesn't have a hitch, so odds are pretty good that it hasn't pulled a whole lot.
Goodyear Wrangler RadialWhat kind of tires does ur Mazda have?
The one being offered has rust at the bottom of the passenger doorgo with the cherokee. by far the better option.
The bronco 2 will be a 2.8 throttle body injection. I would stay clear as parts are hard to find.
Explorers are great little vehicles. That 97 will have an 8.8 with disks, it's OBDII so a little easier to pull any codes, and as long as it's a OHV and not an OHC, the engines are super easy to work on and mainly trouble free mechanically. They will go 300,000 plus miles easy as long as they are maintained properly. Contrary to popular belief, they are not anymore rollover prone than any other SUV of similar size. Only thing to shy away from is "control trac" 4x4, it's basically AWD with no true 4x2 mode. The 4R transmission was a little undersized, but an external cooler and keeping fluid at rhe proper level helps them last.
Can you tell I have a thing for explorers?
Between a 97 and a 00 Explorer, both 4.0 V-6 4x4 auto...which would you go with?Little broncos are great in the snow, as are the explorers. My 94 has been great, even with 274,000 miles on it and a head gasket that leaks externally, it keeps on trucking. It's lost some of its pep and some of the fuel mileage, but it's great everyday, and for occasional trips with my father's 6x10 trailer. Dad's bronco 2 doesn't do as well pulling the trailer, the short wheel base puts a little too much leverage one the front end and makes steering tricky with any sort of load. I wouldn't want put my lawnmower on it and pull it with his bronco, but I have drug it around with my explorer just fine.
If the explorer is 4 door, you'll appreciate it with kids not having to flip a seat up constantly or your passenger having to get other for back seaters to exit.
OHC or OHV?
