benXJ
- Dec 5, 2005
- Raleigh NC
Picked this up from the forum here not long ago ....not knowing that a real estate deal was coming my way the next week.....so thinning the herd.....mainly for time sake ....it's just gonna sit
1999 XJ, 4.0, 5speed, 231, SYE and shaft, 6.5in long arm lift, upgraded '1 ton' steering, rear 8.8, track lock front D30, 4.56 gears, almost brand new 255/85/16 AT4w on 5.9 ZJ wheels, 229k miles
Needs the front pinion angle adjusted for highway speeds with the front shaft. It vibrates above 45mph. The front shaft is out now, as I've been hitting the highway with it.
I've done a ton of little things to it since I've had it, but it still needs a driver door lock switch assembly
The power lock switch is broken, but all power windows work.
It runs and drives as great as an XJ setup like this should.....bit of harshness here and there, but it crusies straight at 70mph all day
Great oil pressure, no smoke, strong newish clutch, and very little weepage, no CEL or other warnings, no rust or corrosion. Paint has scratches and some fading clearcoat on hood and roof. No cruise control on this one, but it has vanity lights on both sunvisors!
$6400
$6400
