I just saved up and finally got my first jeep wrangler its a 1998 Sahara and it runs great previous owner installed a new clutch shifts smooth, no engine problems. It has some rust but I'm working on that. The only real problem is that occasionally ie every few days or so I'll have trouble with first gear in that when I go to shift into first it will shift in but it feels almost as if first isn't completely engaging and my jeep will "buck" almost like its trying to get the gears to grip but it won't and I'll have to take it out of gear and come usually to a dead stop and shift back in and go about my merry way. When it does this the engine doesn't make any sounds nor does the transmission grind, and if i try to give it more gas because I at first thought I was shifting it into first with the rpms too low it will make a knocking sound. I've mentioned this problem to a few people and I've been told I need to find out if the previous owner had the flywheel resurfaced when the clutch was replaced, and/or I need to bleed the clutch.
Just wondering if anyone has had this problem before or if anyone had some advice or pointers. I'm kind of teaching myself as I go with everything as far as mechanically working on the jeep so any help for a newbie at all would be greatly appreciated.
