DLOR
- May 13, 2007
- Chapel Hill
i am having trouble with a 2000 cherokee 4.0 auto. 132343 miles. it has a rough idle and almost lopes like it has a cam in it. it sputters on acceleration and under load going uphill. also a p0302 keeps coming up. the higher the rpms the smoother it seems to run. i feel it may be off in the timing but not sure how to check that. it had a cracked head and low oil pressure when i got it. i bought a new head from clearwater on fleabay and had a complete running 1999 xj for parts. i swapped the head onto the the 99 block and this is where i am now.
things i have done:
checked #2 injector and swapped it with #3
voltage at #2 is 13.67V, checked continuity and wire harness between the injector and the pcm on the ground side is good.
set the cam sensor using toothpick method at #1 tdc
replaced the following sensors with ones form the 99:
TPS, MAP, IAC, ECT, ITS, CKS, new front o2, the entire cat back, and cleaned the throttle body
i have a crappy scanner and these are the results at idle
fuel psi: 48psi (with gauge)
manifold vacuum: 16-17iHg (with gauge)
engine rpm: 682-703 rpms
TPS: 17%
ECT: 203 Deg F
Intake Air Temp: 126 Deg F
O2 sensor 1/1: .06-.08V
O2 sensor 1/2: .82-.94V
Spark Advance: 4-6Deg
Calc Engine Load: 4.7%
Fuel Sys Status: Closed
long term f/t: 7.8%
MAP: 12iHg
Not sure if any of these are within spec. any help would be greatly appreciated.
thanks kelsey
things i have done:
TPS: 17%
ECT: 203 Deg F
long term f/t: 7.8%
MAP: 12iHg
thanks kelsey
