Lurch830
messin' with sasquatch
- Mar 1, 2007
- Wilton & Albemarle, NC
My F250 is starting to make an intermittent noise and I cannot figure out what it is, so I'm looking for any ideas/suggestions to check before I start moving. The noise sounds like a cross between a bearing being worn out and a chatter; it will last anywhere between a few seconds to a couple minutes and over 150miles/2.5hrs it could not happen or happen 4-5 times. It doesn't seem to happen under 40MPH and it doesn't sound like its RPM dependent (revving it or putting in neutral doesn't seem to change anything). My mind could be messing with me, but I seem to feel it in the firewall and the steering wheel & it sounds like its coming from the driver's front wheel, but I cannot find anything wrong on that corner. So far I've checked & double-checked all the fluids, u-joints, wheel bearings, brakes, pads & calipers. Nothing feels loose, no evidence of rubbing and/or heat and the brakes don't have any odd wear patterns. The only noise I can hear is the backlash in the gears and from my limited experience they seem within spec. I'm going to crawl over it again tomorrow double checking that everything is greased, but I'm hoping to make my first trip over the long weekend so any help would be appreciated!
Thanks,
Brandon
Thanks,
Brandon
