Zane Pearce
- Sep 28, 2009
- Lincolnton NC
Per my previous posts I just installed a rebuild 4.0 into my tj, got the proper block and everything is installed. When installing everything into my long block i set my cam position sensor for timing as accurately as I could referencing my FSM and youtube. The engine is now completely installed and will not start up, the engine cranks over and will backfire/pop but wont fire up. There have been a couple of times it sputtered as if it was going to start but still nothing.
I went ahead and ordered a new crank position sensor and cam sensor and i'm gonna replace both today and try and confirm my timing is set properly for the 3rd time. I will also check for spark and if need be ill pick up a guage to check for fuel pressure but i have no reason to believe anything is screwed on my fuel side as nothing was actually disconnected.
Also I believe my grounds are good but ill have to check and recheck them too. I have heard various stories about issues with initially getting everything properly set to crank up a rebuild 4.0 properly and I'm looking for any advise on other things to check if changing the sensors and setting the timing dont make it fire right up, anything that would keep the dang thing from starting up i'm down to hear.
Thanks
Thanks
