2000 TJ dash center lights
Zachs
Kinston, NC
Can't figure out why these don't light. Pulled a bulb, looked great. Front and rear turns still work, but the dash won't light up for any 4 of those lights. Turn the lights on and the dash does have lights, but still, turns, brights do NOT light. Just put in a new oem flasher.
Problem started when jeep wouldn't get enough power to start on its own. Had to daisy chain two batteries together for it to start (did end up replacing battery). Anyway, started jeep, removed one of the batteries, took it for a trip around the neighbor hood when the battery gauge maxed out so I quickly parked it. Center lights never lit back up.
I've checked all fuses and they are fine. Any ideas?
Did you check the under hood fuses? I had something similar happen to my dash and fog lights and ended up being the ext lights fuse under the hood.
Checked all fuses inside and out and everything is fine. This is killin me as I'm trying to get it up for sale soon.
Have you checked to see if the bulbs are good? Maybe swap them with others on the cluster?
Sent from my Tapatalk using IPhone.
Welllll I moved the bulbs around and everything started working...visually all bulbs are fine, but go figure this was the fix.
That's odd, you moved the bulbs and they work in the other spots?
