This is a buddy of mines XJ. Its a 2000 Sport with a 4.0 and an auto tranny.
About a month ago it started missing. At first it wasn't bad just every once in a while. It started getting worse and started smelling like it was running rich a couple of weeks ago. It threw a code for #3 cylinder misfire.
With the fact that it was running rich we assumed that the injector might be stuck open so we replaced that injector. It didn't change anything.
Next we took a stethoscope and started listening to each injector. All of them had a steady sound to the except for #3 it was sporatic.
Annother buddy of mine thought it might be the ECU. So we came across an ECU cheap and we swapped it out. Still no change.
After that we thought it might be the crankshaft position sensor so we swapped it out and still no change.
I had a camshaft position sensor at home and we swapped it in still no change.
I have thought about the coil packs and plugs, but if it were them, it dosen't explain the sporadic way the injector is firing. It was running so rich at one point it was actually blowing raw fuel out the exhaust. We are at about the end of our rope on this one if anyone has any ideas I would appreciate the help.
