ok so its a 01 tahoe with autotrac and a 4l60e....the tranny will be going soon (used for towing for 40k miles) wanna replace it with somthing better will a 4l80e work? and the rear is a 10 bolt with locker right? can I upgrade the rear end also...
My (wife's) 01 has 165k on it and still going strong.
Has towed my K5 to Tellico 3 times and pulled a Ford tractor all over upstate SC....change fluid often add a cooler and they will last longer than you think.
That said, yes a 4l80 can go in there...but not without spending a bunch of time & money.
with the 4l80e it might throw check engine codes.....Just a thought. My friend put an aw4 in his 03 tj and couldn't get it pass inspection becuase of the check engine light.
