I have an ‘02 1500hd that has not had reverse lights, and will not shift into 4lo, for as long as I have owned it (4-5 years maybe). Last week I decided to replace the position switch on the side of the transmission thinking that was most likely the problem, since the taillights and the connector under the bed are new. Some previous owner did a terrible hack job on the wiring, and the new switch did not change anything. After looking online I decided the 7-wire connector was missing a ground wire, so I ordered new pigtails and spent some time replacing them today. Still no change. Where else do I need to look? I’m thinking the 4-wire connector must be wired correctly as the truck will only start in park and neutral.
For the 4WD, it will shift between auto, 2wd, and 4hi just fine. But will not go from 4hi to 4lo. You can hear it clicking as if it’s trying to do something, but no grinding or jerking. Just noises that sound like the shift motor is trying to get lined up. Then it kicks back to the previous position.
