BugsandJeeps
Member
- Oct 12, 2006
- Concord
I have a coolant leak that I can't find. Suburban 1500 with the 5.3. My driveway is on a slope and I tend to park facing uphill. Lately I have been noticing a small stain on the driveway and looking at it, it is coolant. I crawled under the truck and it appears to be running down and dripping from the base pan. I have looked all around the block and the hoses and see no leak. This has been more noticeable since it has gotten cold. I am topping up the resevoir to keep it full but need to find the leak. Any ideas?
Mike
Mike
the dexcool runs and drips off that lower wiring harness. options depends on milage. if you've got over 80k and have never repaced the pump i would recommend replacing it instead of just replacing the gaskets. if you need to wait, make sure you check your coolant level on a daily basis and keep it filled to the proper level.
