2005-UP FORD SUPER DUTY DANA 60 SHOCK BRACKET KIT
Barnes 4wd
Etowah NC
Introducing our new 2005-up Ford Super Duty Dana 60 shock bracket kit. Designed to mount your shocks on your Dana 60 front axle. The 2005-up Ford Dana 60 is a large improvement over previous Dana 60 front axles, however there is not as much room on the axle tubes for mounting suspension components. With this bracket kit you can mount your shocks in the same location that the factory coil springs were, this frees up much needed space on the axle tubes to mount other suspension components. This kit will come with 2 shock brackets and 2 bolts for mounting. The brackets are manufactured from 1/4 inch steel, they have a 1-1/2 inch inside mounting width, a 1/2 inch bolt hole and will ship bare.
superduty-dana-60-shock-bracket-jpg.258958
coil-spring-2005-up-superduty-shock-mount-jpg.258959
dana-60-shock-bracket-jpg.258960
SHOP NOW
