Bigbluechevy
Member
- Jan 20, 2009
- indian trail
Hey guys, I am just out having fun in the truck.
I made an intake setup on the truck to flow better.
Seems like the code could be related to the intake system I added, but I want to be 100% sure on what the problem is. Instead of guessing its the intake, since this happened when I upgraded it, so I am trying to find out WHY the intake could throw the code compared to the stock one.
Obvious things I should point out:
more CFM passing now due to de-restricting
Temperature more sensitive with high-flow filter
I put MAF/IAT1 sensor at two different locations in the intake pipe, both locations gave a P0101.
Every seam has been checked for air leaks to rule that out also.
I am using a dry filter instead of one that uses oils to avoid contaminating my MAF/IAT1 sensor.
MAF/IAT is sitting correctly in the intake tube, and not leaking. All live data from this sensor indicates no electrical circuit malfunction, so I would like to compare my live data at idle to someone else, or from a dealer example.
I have been looking for files of live data available online for this truck(stock form) specifically to compare to what I logged on my Solus. I am interested in the following graphs:
Engine speed
Coolant (f)
IAT 1(f)
IAT 2(f)
MAF (g/s)
MAF (v)
MAP(inHg)
BARO(inHg)
I am wondering if anyone on here has a live data set from within as recent as possible(to compare data from similar weather patterns) they could email me?
-OR-
I can upload my live data into a thread here and you gentlemen can analyze it to compare it to something you might have that you cant email me.
I am not looking for opinions as to what might be wrong with the truck, But I will consider all facts if someone speaks up.
I really just need a clip with about a 250RPM section to compare my numbers to. And if someone emails it to me, feel free to add whatever info you think is necessary.
My email address is Cwoodar0@email.cpcc.edu
Thanks, Connor.
Engine speed
Coolant (f)
IAT 1(f)
IAT 2(f)
MAF (g/s)
MAF (v)
MAP(inHg)
BARO(inHg)
-OR-
Thanks, Connor.
