1997tj
- Mar 2, 2010
- Greevnille NC
Im working on this jk at work and the head gasket is blown on the number 4 cylinder. Its not just leaking coolant it blew the gasket around the combustion chamber. The heater core is also busted but they already had that bypassed. None of this happened until they had the supercharger installed. I called RIPP to see if they had ran into this or had a solution but I wasnt able to get much help. They were more defensive than helpful. He said the headbolts were probably loose and that was a common problem with the jks. Trust me they werent loose. He also said these only put out about 6 to 7 pounds of boost and shouldnt cause any issues. Is there supposed to be a programmer? I dont see how you can add that much air without adding fuel or adjusting the map or something. The cylinder does not look like it has been ran very lean. There is a long history on this thing and it has been to many other "jiffy lube" type places that wouldnt do the big work and thats how it ended up here. I know they have a lot of these things sold so I wouldnt think they would cause this issue but why else would the head gasket be blown there at 40,000 miles? Whats yalls opinion?
