Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
I figured I'd go ahead and start this before I forgot. I've got a bunch of pictures to resize on my phone before I can post them.
The main objective here is to replace the oil cooler in my LB7. I just happened to see some stuff about the 2020 L5P cooler bolting up to all previous generations and being literally twice the size of the LB7, LLY, LBZ, and LMM coolers. 10 plates vs 20 plates! LMLs went to a 14 plate, IIRC, and 2017 to 2019 early L5Ps used a 17 plate.
I had gotten some weird stuff in the last two or three oil samples I sent in and decided that changing the oil cooler would be the easiest place to start. I'm the type of person that always looks for an upgrade with a replacement, if possible. Stock worked well for 315,000 miles, but might as well look for something better!
So, Duramax engines have never seemed to have much concern with oil temps. They don't monitor it and haven't monitored it until a few years ago. We all know that when oil gets hot, oil pressure drops. In stock form I'm sure everything would be fine. I don't live that stock truck lifestyle
In my searching, I also found that replacing the cooler with this newest variant is cheaper. The cheapest complete assembly I found was 290 bucks (plus gaskets) and the cheapest cooler stack was around 200 plus you need a full gasket set to the tune of about 60 bucks and you have to disassemble it. There's also no replacement gasket between the halves for the earliest LB7 oil cooler, so you'd have to replace it anyway. It was a metal framed gasket covered in silicone. Later ones use a large o ring that sits in a machined groove.
2020 L5P Cooler: 112706188 supercedes old PN 12701592 ($205)
Adapter: 12675428 ($10)
Gasket: 12676826 ($4)
Pictures are posted in order of part number listings and you can see the part numbers on the bags they came in from GM.
Prices rounded up to the nearest whole dollar and vary slightly from place to place. I got them from GM Parts Direct.
It does use a different oil filter than 2001-2019. It's an AC Delco PF26 filter. Cross reference that to your particular brand preference. Make sure it has an anti drain back valve and bypass valve at the proper pressure ratings. I used an Amsoil EAO11. It's a slightly smaller filter, but that doesn't necessarily mean it has less pleating inside of it. I'm sure someone will eventually make a longer filter for it if the demand is there.
Thus far, you can order the parts and know what you're getting. The next post will let you know what few extra things you'll need over a standard oil cooler replacement job.
