2022 TOYOTA single seater buggy
ProbablyBroke
does not torque to spec
Reidsville
Up for sale is my 2022 Toyota based buggy. $12k or 11k without wheels/tires
Located in Stoneville, nc 27048
It has probably 7 weekend rides on it since we finished it in 2022. It’s as simple as you can make. Takes 2 minutes to get used to straddling the transmission and shifting gears between the legs. All t case shifting is via cable on the right side of chassis. Easy to get in an out of via left side.
Chassis is 1.75 DOM finished in 2021.
22r on propane, 2 tanks
GM one wire alt, PSC Pump, Howe filter/ resi
Pusher fan and mechanical fan.
LCE header, battery box welded in.
Dual cases, 4.7 in the rear case w/ cable shifters
1/4” plate skid skinned with 1/2” HDPE, 3/8” plate t case armor at the rear.
Warn x8000i with synthetic rope, rear suck down
Corbeau Baja and PRP harness
1/4” drive shafts and Scott’s carrier bearing (nice)
V6 Toyota IFS width rear axle with 4.10s, welded
Front axle is a Diamond housing, 4.10s welded, 6 shooter knuckles, trunnion bearing eliminators, drive flanges, Tacoma brakes, single ended full hydro steering with 1/4” tie rod and armor
4 link front and rear with 14” fox air shocks
1/4” wall links
Brakes are vacuum boosted with model T retrofit
17” trail ready beadlocks (5)
40” sticky Goodyear mtr (5) grooved/ cracked but hook up to well.
Quick release Fire extinguishers
HF Pelican case for tools/ ammo can dry storage.
Any questions, just let me know. Not interested in trades, only selling to put money toward our house.
12k$
I will sell the buggy for 11k if I keep my wheels/tires.
Located in Stoneville, NC 27048
704-277-99forsix
WTF? Nooooo…..
