205 Oops
orange150
Fairfax City, VA
not sure if this is the right section for this
so i was cleaning my 205 gettin it all purdy when i realized that getting into all the little corners and things was getting hard and annoying. so i took off the rear out put housing to make things easier and of course, its full of fun little needle bearings which just happen to all fall out, i also find out that there are gaskets between everything. Sooo as long as i have it out of the truck, and sort of apart, is there such thing as a master rebuild kit for one of these that has all the gaskets and such in it? and if so can you get it locally?
thanks!
I dont know of anywhere to get the required parts. I just want to say I feel for ya! stuff like that happens to me all the time. :D
Drivetrain Specialists in Las Vegas and.... another company up in MN or thereabouts whose name I can't remember.... both stock rebuild and gasket kits for the 205. I've done business with both. NAPA can probably get them in a few days, but I've never asked.
That said, unless the output seals are shot, I'd just RTV it and put it back together. A little bit of grease will hold the needles in place while you reassemble the parts.
yea im not worried about the needle bearings, dealt with my fare share of those and learned the grease trick quite fast! you're right about the RTV... didnt even cross my mind :rolleyes:
