toyotafreak
they call me spaz
- Nov 14, 2006
- China Grove/Mooresville
alright, i recently rebuilt the 22-re in my 89' DD... shorty there after it started acting up and the check egn light came on, so i ran codes on it and it spit out like 10 diff. codes. So i started changing them one by one, i changed...
-both sensors in the lower intake
-throttle sensor
-AFM
along with pulling the CP apart and cleaning the grounds, and cleaning surface contact to the cab, running an extra 6 ga. ground strap from the batt. to the block, block to frame, and then from the block to the cab. Also grounding the head to the block through another 6ga. ground strap... after all of this it is still giving me the codes 41, 51, 52... i know one is a knock sensor, but other than that it is still running weak.
Does any one have any ideas?
-throttle sensor
-AFM
