paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
from my thread earlier:
http://www.helmarparts.com/product_p/fb-200m-1.htm
your mixer should look like this without the throttle body attached
the port that the LP vapor line connects to, just below is the "load mixture" adjustment, ( CA100 is usually used on 2.2L-3.0L engines )
The fat head screw to the right is your idle mixture.
next question, your tank is full, right ? ( I see this A LEAST once a month )
how is the tank positioned ?
you are using a forklift tank, right ?
you can see the mixture screw for load in that picture.... if you look in the vapor port, it is just a valve that allows fuel in.... You could be right at idle, but lean under load... that load screw only turns ~90*
