22r to 3.0 trans swap
So IIRC the bellhousings can unbolt from the tranny, so if you get the bellhousing that matches the 3.0 it can swap.
The V6 5 spd trans is the r150. It would have the bellhousing you need to bolt to the motor. I know the bellhousings from the turbo (r151) and the v6 can be swapped, I've done it. But I don't think it will bolt to a w56. I'm not 100% sure though
