Archdukeferdinand
- Dec 27, 2006
- Vilas, NC
Believe my 22re Jumped time. Long story. I can see the driver’s side chain guide is gone, so my suspicion is that it’s a jumped tooth or 2 off, didn’t think to check the balancer because I was so pissed at what I found.
With those marks lined up, the notch on the crank pulley is about 15-20* past 0 on the timing marks. Also the valves that should be are loose, the ones that should be tight are tight (for TDC cylinder 1)
With the crank pulley notch at 0, the little mark on the Cam gear is shy of 12 o’clock and the piston doesn’t quite seem at the top of the cylinder. (again, #1). Seeing the drivers guide gone and where the chain has begun to eat into the metal around it, I know the timing cover’s coming off. Just double checking what all should be done while I’m at it. Also wondering on good sources for parts as ENGNBLDR seems to be closed.
